Not only should you let us know the brand/make/model of your display, you should also let us know how well they take care of you with the service request you will HAVE to put in for this failure of the electronics.
It is BS politics to not point out that companies fail all the time. Just say what you have and what went down, then go ahead and let us know how they took care of you when you called.
I've had product go bad from Panasonic, BenQ, Sony and others. Electronics generally have about a 3% product failure rate out of the box, so this is not at all unusual or horrible, it's just what the electronics industry is.
But, how they take care of you after you find that you have a problem with a product which is less than 1 year old is incredibly important.
My example: I had a water cooler for those 5 gallon jugs of water. After about 18 months it started freezing up, so I had to unplug it to stop it from freezing the water. After another couple of months it then started leaking, dumping several gallons of water on my hardwood floors... which leaked to my basement. Two very serious issues and I decided to not buy from that company again...
The next cooler I got was from a different company and had good reviews. After 8 months it started freezing up. Guess what? It turns out that it was MADE and OWNED by the original company I had decided not to buy from. In none of the literature I read did it mention that it was just another product by the same manufacturer. Nice.
So, our water cooler is now out for repair, under warranty, where it has been for the last 45 days! We dropped it off at the service center ourselves. Why does it take over a month and a half to repair a product which was purchased less than a year ago?
Greeway HP (Greenway Home Products also dba Vitapur & Watermaxx) - can go screw themselves and they happily threw themselves under the bus.
Hey, I feel similarly about my GE appliances which I got brand new with my home of which I've had 4 repairs on in less than 5 years of ownership/use. GE has lost my business moving forward and rightfully so.
