Why?
Attention experienced Phono Audiophiles.
I just bought a Rega Planar 1. Included in the user hints for long life, they say to turn the table on at the beginning of a listening session and leave it on until you're session is over. The concept is that, if you leave it on and don't turn it on and off to flip or change records, you will save wear and tear on the motor and belt.
My problem with this is, doesn't the sudden jolt caused by you grabbing the edges of the record to lift it off and interrupting the momentum of the spinning platter harder on the motor and belt and more harmful than turning the table off and on?
Opinions please.
