Why does my old crt tube tv I have in the bedroom have a better picture on regular cable than my new lcd tv?
LG42LD550 is the model number.
Is there a setting or something that I need to change? Watching digital channels the picture is great on the lcd but regular cable channels are much better on the older tv's.
Thanks.
It is primarily a function of the size of the TV and the distance you sit from it. The bigger the TV at any given distance, the more details you will be able to see (as the details are physically bigger on a bigger TV). So, a picture that looks fine on an old 27" 4:3 NTSC TV may look terrible on a 42" 16:9 TV at the same distance, because the picture is bigger and it may be that the level of detail in the signal isn't high enough for the larger TV to look clear.
You may (or may not) have noticed years ago with old NTSC TVs in the store, standing close to them, a little 13" TV may seem to have a sharper picture than a 27" TV. That is because the defects are vastly bigger on a 27" TV (over 4 times bigger).
Add to that the scaling mentioned by MDS and matters get even worse. But simply having a very large NTSC TV would look like crap if one is too close to it, but with HD, there is more detail, so one can sit closer to it without it being a problem. There are, however, limits. With your TV, with a 1080p signal off of a good BD (Blu-ray), if you have 20/20 vision, it will look clear at only 5.46 feet away (or further away, obviously). But with a 720p signal, such a size would only look perfectly clear at 8.19 feet (any closer, and the picture will look "soft" and start to look bad, the closer one getting, the worse it will look). And with a 480i signal, you will need to be much further back for it to look equally clear. These things are all assuming that the source makes maximum use of the format, and isn't from a bad print of a film or some other such issue. And with standard cable, we are talking about an analog signal that is subject to all sorts of problems, so you are unlikely to even be getting the full possible detail from a 480i signal.
In general, to have a TV signal look its best, you will NOT want to enlarge it or stretch it or any other thing, so that a 4:3 signal will take up only the center part of a 16:9 screen and have black or grey bars on the sides. If you make it bigger, you will make the defects bigger and consequently the picture will look worse.
