tdenny said:
I'm seriously looking at a Toshiba 47LZ196 LCD 1080p (47 Inch) and have heard some good things about it. I searched the forums but didn't find any specifics so please forgive me if this is a dupe. Anyone know anything about these or have any suggestions on LCD's in that size range?
I have looked at a lot of plasma's and with the exception of the Pioneer 8k model haven't found any I really liked. My primary uses will be the Sony PS3/BlueRay player and HD cable TV.
I am still a bit leery about LCD but need some reassurance from the forum? I'll search around some more but would really appreciate any info. Thanks much.
TD
I recently bought a Sharp 37" LCD TV that I have been very pleased with. It was my first HDTV of any kind. It is 720p resolution, so my comments are general and not directly about your model.
It was a toss up between the Sharp LC-37D42U that I did buy and the Toshiba 37" 37HL66. Both seemed very good, and ultimately price was the deciding factor. From what I was able to learn about both the Sharp and Toshiba LCD TVs in general, I think your choice will be good. You might want to compare the Toshiba to a
Sharp LC46D62U. It is also 1080p. I found the equivalent Sonys were much higher in price and didn't seem worth it.
I was surprised at how good the built in digital TV tuner in my set is for over the air reception. Before you commit to HD cable, if OTA is available for you, give it a try.
