Thare187
I see so many different products. Any product ideas to clean computer, LCD, Nintendo DS and every other screen I have. Thanks a ton
jliedeka
jliedeka
You want to be careful with LCD screens because they have a plastic coating that could be ruined by things like Windex and other solvents. If you aren't cleaning anything oily like fingerprints, a microfiber towel moistened with plain water is okay. If you do need to get fingerprints off, the only safe thing I know about is something that Monster sells that is probably overpriced.
I would speculate that dilute soapy water to clean and plain water to rinse (applied with towels) would probably be safe but maybe someone else knows better.
Jim
MDS
Every single manual for an LCD TV I have ever read says what jlideka said - a soft cloth lightly dampened with water or a mild soap.
If you use one of the cleaning kits, always spray the solution on the rag and not the screen itself.
Jack Hammer
Jack Hammer
The previous two posts nailed it. The only thing I've heard to use is a microfiber cloth and water. And to wipe very gently, no rubbing or elbow grease, just a soft touch. And definately no household cleaners.
Jack
