In a dual sub configuration, which would most likely be the better layout (x is the sub)?
l x l x l
or
xl l lx
Once I get the subs I will do my best to try and find the best location for each sub…but WAF may come into play and my choices may get limited to these layouts unless I can dramatically prove an improvement in another location. So basically, the first option allows me to place the subs below my screen spaced out between the main speakers and the center channel. The second option would have the subs loaded tight into each corn with the mains tight right next to them.
Well, I know I will play with the configuration when I get the speakers…I’m just curious what I should expect the better config will be…hopefully I won’t be limited to only these two though.
