Large room needs small speaker
Tazmoj
Considering Veritas V-5.1, Dynaudio DM2/6 or PSB imagine mini ?? Bought an older home w/ large great room. Legacy spkrs are Bose. Prewired. I can fit a bookshelf speaker. Driving with ONKYO nr609- 100wpc. Rears mounted up on ceiling 15 ft up/behind. Mostly home theater..Which will have the best output?? Budget 300-400 each.
Open to ideas, please help
K
kini
Home theater mag just did a review on the PSB Mini- they really liked them but ininuated the need for a high end amp for them to sound their best.
So in addition to the fine choices you have already mentioned-
Swan (from theaudioinsider) makes some nice small monitors like the
D1.1se at $499/pair with a 30 day trial. Size 11.5 x 6.75 x 9in- they have a matching center too
Martin Logan Motion LX16 $799/pair list Size 11" x 6.5" x 9.5", can use the moition 6, 8 or C for center
NHT Classic Two- $299 each, Size 12.125"Hx 7"Wx 8.875"D (sealed so no need to worry about ports, easier placement) also have a matching center
B&W 600 series bookshelf speakers, front ported, not too sure on the size.
KEF Q100, front ported, $550/pair, size 11.8 x 7.1 x 10.7 in, matching center available
Hope this helps.
Gene
lsiberian
lsiberian
Is this for surround duty or main duty?
CBM-170 SE High Performance Bookshelf Loudspeaker are probably the best bookshelves under 400.
If you are fudging the budget the Infinity Primus stuff at harmanaudio.com is very good.
Tazmoj
I would want a center, 2 fronts and 2 surrounds. The surrounds have to be ceiling mountable so they'll need to wiegh less than 12 lbs. Thank you for the link!
