I live in a flat and my main living area consists of a large square area of 23 x 12 feet in size. The roof is made of thatch, slanted, and rather tall - 10.5 ft to the lowest slanted points, 18.5 ft to the highest point. This gives me a total volume of 3300 cu. ft. There is a upstairs area which is roughly half the room footprint, 11 x 12 ft, which is just a suspended wooden floor. For a number of reasons my girlfriend and I have decided to dedicate this area to entertainment. Here are two pictures to give you some idea:
http://photos5.flickr.com/5361349_75d6699571.jpg
http://photos5.flickr.com/5403903_e476368972.jpg
Now the roof being 1) slanted, and 2) thatch, I expect I won't have many issues with sound reflection. The front and back walls are parallel however there is a large fabric hang on the wall behind the couch, a bookshelf on the one side, and open space on the other (there are thick velvet curtains downstairs).
Is there much I can do to make things sound better or am I just stuck with a compromised environment? I will probably get a set of stands for my rear speakers and move them around to their ideal positions whenever listening/watching, and get two granite/marble slabs made up for the front speakers as to reduce floor vibration.
I am planning on using floor-standing speakers for the front, possibly Diamond 8.4 (86db sensitivity, 6ohm "nominal" impedance) with matching Diamond centre and surround speakers, Pioneer DV-575A player, and a Yamaha RX-V450 (rated 85wpc). Do you guys feel this should be enough to fill the room? (Will most likely never use the top half of the power-scale on the amp...) Any mis-matched components? I currently have a cheap set of cubed speakers and they do the trick for movies, music leaves a lot to be desired however.
Another big question mark in my plan is whether I should use monopole or bipole rear surrounds - I feel that since one wall is effectively "missing" from the h/t room, a bipole will not be a good idea since the ambience sounds won't bounce back. Also, since I have limited space around the couch, I would like to put the surrounds on stands so they can be moved out of the way and closer to the wall when they're not in use, and aim them at the listeners whenever in use. Maybe I could add a bipole speaker on the wall as the rear surround channel later, as the RX-V450 has 6.1 outputs.
My budget is flexible as I'm building this piece by piece, however the choice of components should give you an indication of the price ranges I'm looking at. I am in South Africa and unfortunately prices locally are rather high - for example the RX-V450 retails for upwards of $500, compared to $200-300 in the USA. Also the choices of equipment are rather more limited, further complicating the decision-making process.
Anyhow, any advice and suggestions would be much appreciated by a total home theater newbie!
