laptop to TV via VGA. Help!
Desert Toad
I am trying to complete the simple task of getting my Toshiba Satellite laptop to output to my television.
Equipment: Toshiba Satellite L305 running Vista, Sony Bravia 52V, Integra 6.6 receiver.
The only output on the toshiba is vga, the tv has a vga input (called pc in). When I connect, I get a picture on the tv but it is dim and only grayscale. I have changed all kinds of settings, but nothing helps. The cable is a 15 pin vga I just bought at best buy.
Would I be better off with some sort of HDMI converter and plugging into my a/v receiver?
What am I doing wrong? This is SO frustrating!
I have looked at your manuals. Your TV does not have a VGA input. It is a PC HDMI port. You can't convert your computer output to HDMI.
I don't see a way of connecting that laptop to your TV. I think it is new laptop time.
Desert Toad
Oh thank you thank you thank you!!!
I have been a couple weeks with nobody telling me anything! At least now I know why it won't work. I've only had this laptop a couple years, and I bought a cheap one since it only serves to complete one work task.
So can I get a HDMI converter box and connect that to my tv or receiver? They are bit cheaper than a new laptop. ;-)
thanks again!
pzaur
It does have a VGA connection, it's called D-sub.
It sounds like the cable may be bad, the board might be bad (at the TV), or you simply have the PC outputting grayscale for the 2nd screen. Have you tried a different VGA cable yet? Be sure to check the color settings for the 2nd monitor at the PC.
There are convertors out there for VGA to HDMI. Here's a short monoprice.com list.
-pat
-pat
When did VGA get called d-sub?
jinjuku
jinjuku
Moderator
Page 10 of the Sony user guide....
Clearly shows a VGA port. Often referred to as D-Sub.
Desert Toad
Ummm.......Okay. So if it is a VGA port, why isn't what I am trying to do working?
digicidal
digicidal
Based on what you are describing I would try a different VGA cable first - and make sure that the connections are secure on both ends. With analog video connections if all of the pins are not firmly connected (or if there is a break in one of the signal wires in the cable itself) then you will have color dropout - which can look like a faint gray screen (or faint red screen, or blue, etc...).
If you try another cable and it still doesn't seem to be changing, then I would also try dropping your desktop resolution to something like 800x600 or 720X480 if widescreen @ 60Hz at first. It's possible (tho less likely) that the TV is responding to an invalid refresh rate or resolution. If it looks good at that resolution, then try upping it in single increments until you reach the optimal res.
The other thing to make sure of is that (at least at first) you are switching over to the TV completely. You'll need to check your manual for the Toshiba, but usually if you use a combo to switch (like Function+F5 or similar) you have three modes: shared - i.e. desktop extends from the laptop screen onto the TV, cloned - both screens show the same thing, and swapped - your laptop screen is turned off and the TV is used as the only display. I don't know the specifics of the card you have in that laptop - but you might not have enough memory for running in dual-desktop mode at the resolution you're set at. By using the TV as your only display you can at least narrow down that possibility.
If you have another PC around with a VGA output on it - try using it to troubleshoot. If you connect it and it works - it's your laptop video card / laptop settings. If it looks identical to the laptop... then it's the cable or the TV's VGA input. If getting a new VGA cable doesn't change that... then it's DEFINITELY the TV... if it does, well then it was obviously the cable. If you got one of the Best Buy brand cables - I forget the name but the blue blister-packed cables they have all over the store - then it's possible (I would even say likely) that it's the cable. I've never had good luck with anything they sell in their own brand and the prices are ridiculous. Hit up Radio Shack or a Frys or even Walmart and you'll get a better quality cable for less money.
@TLS : BSA's link covered everything I'm sure (didn't look to see for sure) - but basically VGA is ONE of the numerous types of D-Sub connections. D-Sub simply describes the connector type itself... however, VGA is probably the best known with 9-pin serial being the second and 25-pin parallel being the third.
digicidal
digicidal
-pat
Wow... missed this post entirely... now I just feel stupid. :cool:
Guess my post above should just say "What pzaur said... um, yeah" :)
Hi Ho
Hi Ho
D-Sub is the technical term for the connection used by VGA. More specifically, it is a DE-15F connector.
http://en.wikipedia.org/wiki/D-subminiature
Any luck with getting it to work? I have had more trouble with VGA connections on laptops than I would like to admit. I don't understand why they seem to be so finicky. I have only tried to use the one on my Toshiba once and I never got it to work. I use the S-Video output regularly on a standard TV in my bedroom without a problem.
