Klipsch Synergy F2- Need screw on feet.
thedannimonster
I purchased a couple used Synergy F2's, unfortunately one of the speakers is missing one of the screw on feet (I.e. one of the four very bottom plastic bits that screw into and can be used to level the unit). Does anyone know where I could purchase a part like this for the speaker?
I thought I found it online and ordered... only to receive the entire plastic housing (that the bottom leveling foot screws into), but not the actual foot that I needed. Maybe I'm just searching using the wrong name for the part?
Thanks a million for any help! The coaster currently leveling it just doesn't look right.
markw
You might try to initiate a dialog with Klipsch themselves on this.
Steve81
Steve81
Audioholics Five-0
Ditto. I was able to get some feet from them for free on my old RF-5s. Barring that, the Klipsch speakers I've had (RF-5, RF-15) have been threaded for a 1/4-20 insert so you could look for something at Parts Express.
jotham
The easiest way to deal with this, is take one of your existing feet to a hardware store and use their screw guides to figure out what size screw you have. Then you can probably rig together 4 new feet using random stuff at the hardware store. Just make sure that the bolt that you purchase isn't too long because if it is, you may accidentally rip out the screw insert.
At the very least, you'll know the correct kind of screw foot you need even if you don't use hardware store parts to put one together.
