Klipsch speaker set up.
RWord
KLIPSCH CA-800-T-B 8" 70V OUTDOOR SPEAKER BLACK
Perfect for foreground or background distributed sound applications in indoor or outdoor residential commercial or recreational environments, the compact full-range 70-volt CA-800T loudspeaker was designed for those who know better than to expect mediocre output.
  • Paintable UV-resistant ABS enclosure with rustproof aluminum grille
  • Very high sensitivity and power handling
  • Built-in 60-watt 70V/100V multi-tap transformer with 8-ohm bypass
  • 90 degree x 90 degree Tractrix Horn tweeter for clean clear highs
  • Supplied with C-style mounting bracket and stainless steel hardware
Specications
Frequency Response:64Hz-17.5kHz 4dB, 47Hz-20kHz -10 dB
SENSITIVITY:96 dB
POWER HANDLING:100 watts (21V) 40Hz-10kHz
MAX CONTINUOUS OUTPUT:113 dB
NOMINAL IMPEDANCE:8 Ohms (4.5 min @ 167Hz)
TWEETER:One K-150-A 1", titanuim diaphragm compression driver
WOOFER:One K-1183-A 8" woofer, IMG Cone
CROSSOVER FREQUENCY:1900 Hz
ENCLOSURE MATERIAL:All-weather ABS Plastic paintable to match dcor
ENCLOSURE TYPE:Vented System via port
INPUT CONNECTIONS:Barrier Strip
COVERAGE ANGLE:Horizontal: 80 40 1.2kHz-20kHz Vertical: 90 30 1kHz-20kHz
DIRECTIVITY INDEX:7 2.5dB 700-20kHz
DIMENSIONS:11.125" (28.258 cm) H x 16.375" (41.533 cm) W x 12.313" (31.275 cm) D
WEIGHT:18lbs (8.16kg)
TRANSFORMER TAPS:60W, 30W, 15W, 7.5W, 3.75W
Built From:2005
I bought 7 of the above speakers from a Restaurant that went out of business for my home game room and would like to know what would be the best setup? What Equipment should I buy?
BMXTRIX
BMXTRIX
Is your idea just to throw a bunch of speakers around the game room for music listening?
If your goal was TV viewing/movies with surround sound, then sell the speakers as they are not appropriate for home theater use. They say right in the description that they are for distributed sound applications in a commercial environment... not home theater. This makes a difference because they are 70v speakers, not 8 (or 4) ohm speakers.
You pretty much gave us the absolute minimum information you could on asking for help.
The BEST setup would be completely different speakers, a really nice amplifier, a incredible preamp, a lossless high bitrate audio source of the highest quality, super nice speaker cable, and a budget of $100,000+.... Since you asked for the 'best'.
Sarcasm aside, you really need to figure out what you want. What do you want to listen to? What are you hoping to accomplish? What is your end goal?
At this point you have some commercial speakers you have in your home, and it seems like you don't know why you bought them. So, figure that part out and you will get more direction on whether they will work for that.
THAT SAID: 70v amplifiers are available on eBay for not a lot of cash which will power all those speakers easily. It will be MONO, not stereo, as that's what 70v systems are designed to do.
L
latapx
Those Klipsch speakers do have an 8-ohm bypass and can be used with a traditional amp...not just a commercial audio amp. I looked into using those in my outdoor system before deciding on something else.
