Klipsch SC.5 Center for sale. Used for two movies total!
Buy for $90 shipped (contiguous 48) or p/u in Naperville IL for $80 and save yourself $60 off new. Small dent in one rear corner. In original box with reciept. Will also trade for comparable Boston Acoustics center. Pics on request.
email directly if interested please
p.jasek@comcast.net
FREQUENCY RESPONSE:
70Hz-20kHz±3dB
SENSITIVITY:
91dB @ 1watt/1meter
POWER HANDLING:
50 watts maximum continuous (200 watts peak)
NOMINAL IMPEDANCE:
8 ohms
ENCLOSURE TYPE:
Sealed
DRIVE COMPONENTS:
Two-way system using one 1" (2.54cm) magnetically shielded, polymer dome compression driver tweeter with a 4" (10.16cm) square 90°x60° Tractrix® Horn and two 4" (10.16cm) magnetically shielded, IMG cone woofers
TWEETER:
K-109-A 1" (2.54cm) Polymer dome compression driver
HIGH FREQUENCY HORN:
4" square 90°x60° Tractrix® Horn
HF CROSSOVER:
2700 Hz
WOOFER:
Two K-1097-AV 4" (10.16cm) IMG cone
DIMENSIONS:
5.5" (14cm) x 14.5" (36.8cm) x 6.25" (15.8cm)
WEIGHT:
7 lbs. (3.21kg)
ENCLOSURE MATERIAL:
Medium density fiberboard construction (MDF)
FINISHES:
Matte-finish Black vinyl
YEARS BUILT:
