Klipsch RF-52s vs Paradigm Monitor 7 vs ? Help with new system
Substance-P
It's been a long time since I have been shopping for new speakers. We are moving to a new house and will, for the first time, have a room set up primarily as a home theater as well as a room for day-to-day TV watching and music listening.
I am finishing off a Klipsch system for the HT; however, I am undecided on the family room. This is where I could use some help.
Due to the dimensions of the family room and the placement of the TV, I only have a maximum of 7.5 inches of width for each front floorstanding speaker. Using these limitations, I have narrowed things down the Klipsch RF-52s and the Paradigm Monitor 7s to anchor this system.
The room is relatively small (15X12) but opens into a kitchen. The system will be used for 50% TV watching and 50% music listening. Eventually it will have two outdoor speakers connected to the same receiver as the family room and kitchen open onto a patio.
Any people have recommendations on one over the other or of other speakers that I should be considering?
Thanks
Substance-P
I just listened to the setups for a second time and am leaning toward the paradigm. I am just not sure if I can justify the price difference as they both sound good.
corey
It sounds like you have some space constraints in your room. What about bookshelf speakers as mains, with as many subs as needed/wanted?
