This is a pair of RF-25's for those of you that like Klipsch.
The meat. It's at woot.com.
[/quote]
Specifications:
Frequency response: 45Hz-20kHz ±3dB
Power handling: 125 w max continuous (500 w peak)
Sensitivity: 97dB @ 2.83 volts/1 meter
Nominal impedance: 8 ohms compatible
Crossover frequency: 2633Hz
Tweeter: K-137 1” (2.54cm) Titanium dome compression driver
High frequency horn: 6” square 90°x60° Tractrix® Horn
Woofer: Two K-1123-OB 6.5” (16.51cm) Cerametallic® cone / cast polymer frame
Enclosure material: MDF
Enclosure type: Bass reflex via rear-firing port
Input connections: 2 sets of binding post speaker terminals (connected via brass strap jumpers)
Dimensions: 38.9” (98.8cm) x 8.5” (21.6cm) x 13.8” (35cm)
Weight: 44 lbs. (20kg)
Finishes: Black Ash, Light Cherry wood-grain vinyl
Built from: 2003
Built until: 2006
In the box:
2 Klipsch RF-25 Floorstanding Speakers
8 Carpet Spikes
8 Floor Feet
8 Screws
[/quote]
