Klipsch Quintet II 5.0 Satellites (1 day only) $200
sholling
sholling
I'm not a fan of small satellites but in my opinion the Quintets are some of the better low cost micro satellites to come around. Unlike some of the competition the Klipsch can actually belt out some some pretty respectable volume as long as they're backed by a good subwoofer. The main disadvantage is that they need to crossover to the sub at over 100hz, and it's possible that some might find them a tad fatiguing.
Note" I'm not sure the Vanns' listed power handling specs are correct. I think these from Klipisch are closer to reality:
Sat: 50 w (100 w peak)
Center: 75 w (150 w peak)
Vanns Sale
Vanns said:
Comparison Specifications
* Power Rating: 100 Watts RMS, 200 Watts Maximum Peak
* Nominal Impedance: 8 Ohms
* 0.75" Neodymium Magnet Polymer Dome Compression Horn-Mated Tweeters (1 Each Speaker)
* 3.5" Polymer Dome Compression Horn-Mated Woofers (1 Each Satellite, 2 Center Channel)
* Crossover Frequency: 4900 Hz
* Bandwidth: 100 Hz-20 kHz (Satellites), 120 Hz-20 kHz (Center)
* Cabinet Design: Elliptical, Molded Stone Mineral Compound (SMC)
* Magnetic Shielding: All Speakers
* Mounting Options: Bookshelf/Wall/TV Attachable, All Speakers
Additional Specifications
* Sensitivity: 90 dB
* Connectors: 5-Way Binding Posts
Dimensional Specifications
* Satellite Size (H x W x D): 7.50" x 4.25" x 6.50"
* Center Channel Size (H x W x D): 4.50" x 12.25" x 5.75"
Klipsch Quintet II Silver Warranty Details
* Five-Year Parts And Labor Warranty
Brackets for wall mounting are available from Klipsch.
