http://www.vanns.com/shop/servlet/item/features/544614662/klipsch-promedia-ultra-2-0
Specifications
Power rating: 30W total (15W x 2 channels) / High-efficiency Class-D amplifier
Impedance: 3 ohms, nominal
Tweeter (each): Single 1.0" metalized polymer tweeter / MicroTractrix horn
Woofer (each): Dual 2.5" metalized, fiber-composite cones with neodymium magnets and 1.0" voice coils
Frequency response: 50Hz - 20kHz ±5dB
Connections: One 3.5mm stereo jack input / 1 auxiliary line input / One 3.5mm headphone output / 1 slave-speaker RCA output
Magnetic shielding: Yes
Mounting options: Intended for table-top placement
Additional Specifications
Configuration: Right-channel active control speaker / Left-channel passive slave speaker
Enclosure type: Bass-reflex with tuned port
Controls: Bass and Main Volume controls on control speaker
LED power indicator
Maximum acoustic output: 100dB
Voltage: 120V
Manufacturer Specifications
Voltage: 120V
Dimensional Specifications
Dimensions (each): 3.25" W x 10.5" H x 6.5" D
Weight (each): 7.5 lbs
