Klipsch Promedia 5.1 Ultra subwoofer amp dies
mooky9669
mooky9669
A few months ago my sub stopped working for my 5.1 ultras. I checked out the fuse and it was good...took it to Radio Shack to test...when I turn on my speakers I hear just a click. I unplugged it overnight and plugg it back in, but still just a click...the headphones work fine with the vol. control..I called Klipsch and I hate I'm not under warranty...it expired a month before my sub died...they said if I just send the amp it'll be 60 bucks and I'd prob. have to ship it with FedEx for prob. 5.95 since it didn't weigh much. After reading on the forums about people who have the same prob. many times I kinda don't want to send the amp to get fixed if it takes too long to get back or if I get it back and it dies again and I have to pay another 60 bucks to fix it....the speakers work fine and is there another 5.1 sub that someone could recommend that would be compatible? I have Googled for PC subs, but no luck.
What is the speaker's impedance rating? Maybe you can get just another amp, bypass the built in one.
mooky9669
mooky9669
I don't know really..but here's the specs from the Klipsch site...
Specifications
FREQUENCY RESPONSE:
25Hz-20kHz +/- 5dB
POWER HANDLING:
FTC Rated per Satellite: 60 w/channel @ ≤ 1% THD, 100Hz - 1KHz (Note: all channels driven)
FTC Rated Subwoofer: 170 w @ ≤ 3% THD, 40 - 100Hz
Maximum Burst Power*: 500 w
MAXIMUM ACOUSTIC OUTPUT:
115dB at listening position (near field)
CROSSOVER FREQUENCY:
HF: 3000Hz
LF: 120Hz
TWEETER:
25mm metalized polymer
HIGH FREQUENCY HORN:
MicroTractrix ™ horn
MIDRANGE:
3" fiber composite
SUBWOOFER:
Dual 8" side-firing fiber composite drivers
AMPLIFIER:
BASH ®, dual supply, switching/linear hybrid
ENCLOSURE MATERIAL:
MDF
ENCLOSURE TYPE:
Satellites and center—sealed
Subwoofer—6th order bass reflex
WIRE GAUGE ACCOMMODATED:
18 gauge supplied
INPUT CONNECTIONS:
DIN cable to control module
INPUTS:
6 analog discrete channels (3 stereo miniplugs), Auxiliary stereo miniplug music input
OUTPUTS:
5 speaker level outputs (spring clips)
MOUNTING:
Wall brackets (wb-1) and telescopic floor stands (SAT 2) available at Klipsch web store
WEIGHT:
52.5 lbs
FEATURES:
Center channel has rear post angle adjustment for positioning
VOLTAGE:
120 volt
BUILT FROM:
2003
