I suspect a single PB13U would hold its own reasonably well against a pair of KW120s, at least in terms of raw power.
Klipsch rates the maximum acoustic output of the KW120 as 130dB @ 30Hz, 122dB @ 20Hz, and 112dB @ 15Hz, all at 1 meter, corner loaded. Conversely, the PB13U in 20Hz tune can deliver 115.5dB @ 32hz, 110.6dB @ 20Hz, and 97.4dB @ 16Hz at 2 meters, ground plane, in Josh Ricci's CEA 2010 burst testing. To convert 2 meters ground plane to 1 meter corner loaded, you'd have to add 18dB to the SVS's numbers, to get 133.5dB @ 32Hz, 128.6dB @ 20Hz, and 115.4dB @ 16Hz.
