Klipsch KL-650-THX-R, $500
Paul McNeil
This is an awesome center channel speaker, if you have the space above or below the screen, or even better behind the screen (it is large and not very pretty). I switched from a sound transparent screen to a TV and did not have room above or below and so am selling it. I am the original owner with invoice, the purchase was ~ 4 years ago.
It does show signs of use, including some scratching on top surface.
"The KL-650-THX's listening-window response (a five-point average of axial and +/–15-degree horizontal and vertical responses) measures +1.00/–0.87 dB from 200 Hz to 10 kHz". And it does 115 dB. See this review...https://www.soundandvision.com/content/klipsch-thx-ultra2-speaker-system-ht-labs-measures
For more details go to http://images.klipsch.com/KL650THX_635042118250460000.pdf
48Hz-20kHz ± 3dB
97dB @ 2.83 volts / 1 meter 8 ohms compatible
1400Hz crossover
150 watts maximum continuous (600 watts peak)
Bass reflex via front-mounted port
Medium density fiberboard construction (MDF)
1" (2.5cm) magnetically shielded titanium dome compression driver with 9.6oz ceramic magnet structure and 10" x 6" rectangular 90°x 60 °Tractrix® Horn
Two 6.5" (16.5cm) magnetically shielded, CerametallicTM cone, cast aluminum
frame drivers
Two sets of binding post speaker terminals (connected via brass strap jumpers)
15" (38.1cm) H x 17" (43.2cm) W x 12.5" (31.8cm) D (w/grille)
39 lbs. (17.7kg)
Galaxy Black cabinet with Black anodized aluminum fascia
4-bolt pattern 1/4"-20 thread
You are welcome to visit me in Poland for an audition.
P.S. I'll give you an estimate to the USA for shipping. You may or may not like the cost or duration of transit. But we can discuss....
