Hey guys,
I'm looking at adding to my home theater system that has been pieced together over the years.
I have a room that's ~13ft long * 8ft wide and 8 ft tall, walls on all sides. So it's pretty small, with the couch against the back wall.
I have Heresy IIs as Left and Right, with a Mirage FRx-C-1 Center speaker.
Just ordered an SVS SB-1000 subwoofer
Trying to decide on what to do for surrounds... and hoping you guys can help!
I need some really tiny speakers to use as surrounds, since I don't have much room between the wall and couch.
Staying within the Klipsch name to match the Heresy IIs, I'm looking at 2 of the individual Quintets or the R-14m. I don't think I can go any bigger in depth than the R-14m, and I don't think I can do in-wall. Maybe in-ceiling.
I'm also looking at the Cambridge Minx Min 22 or AudioEngine P4
If I switched out entirely, I'd look at the Elac Debut line, but I think even the B4 is a bit too big to use for surrounds in my room.
Which of those do you think would work better or do you have another recommendation?
Thanks in advance!
(PS - I did have another thread earlier in the summer about using this same setup for a wedding. Ended up going with the DJ for the wedding and it worked out really well, plus the wedding was great!)
