sgtpepper9
sgtpepper9
I've got a pair of RF-63s and was looking at the recommended setup suggested by Klipsch. For the rears they recommend the RS-62s for $999. You can get a pair of RF-82s for $999. Is there anything wrong with using mains for the rears? It seems to me that the mains would out perform the small surrounds in every way. What do yall think?
jamie2112
I would agree with that statement........Bigger is sometimes better if you have the space......
Adam
Adam
IMO, the RF-82s will be more of a discrete point-source than the RS-62s. The designs are just different. The RS-62 looks to be designed to disperse sound in a wider field to give more coverage as compared to the RF-82. Just depends on what sort of set-up you want, really.
sgtpepper9
sgtpepper9
On an off topic question Adam, how do you like your PC Ultra-13? I'm looking at getting one very soon...:D
Adam
Adam
Love it. Absolutely love it. Great punch, great control, and plenty of power. I had wanted something for years that could do subsonic bass, and this sure can.
For reference, I went from a B&W ASW1000 (12" woofer, amp is something like 150W, -3db at 25Hz) to the PC-Ultra. So, I'm not comparing it to some multi-thousand dollar sub. However, it still has me smiling when I turn the movies up ten months after I got it, and I think that says something.
I think that you will be very pleased!
Adam
Adam
BTW, you can check out the difference in sizes between my old and new subs in this post from last year. The PC-Ultra is just a little bit bigger. :)
