I have one pair of Klipch KG-4's for sale. They are in nearly pristine condition and have a (real wood) oiled oak finish. There are two small scuffs on the front of one speaker. Asking $300 plus shipping.
I replaced the tweeter diaphrams last month (old ones are still okay and will include them as well). These are fantastic sounding classic speakers. I hate to part with them, but I cannot find a center channel that perfectly matches their timbre. They are still one of the best two-channel mode speakers I have heard. If you live close to Harrisburg, PA I will gladly demo them.
Here's the specs from Klipch's website:
FREQUENCY RESPONSE:
38Hz-20kHz±3dB
SENSITIVITY:
94dB @ 1watt/1meter
POWER HANDLING:
100 watts maximum continuous (500 watts peak)
NOMINAL IMPEDANCE:
6 ohms
ENCLOSURE TYPE:
Bass reflex via passive radiator
DRIVE COMPONENTS:
Two-way system using one 1" (2.54cm) phenolic dome compression driver tweeter with a 90°x40° Exponential horn, two 8" (20.32cm) front-firing, poly ICG cone woofers and one 12" (30.48cm) rear-firing, fiber-composite cone passive radiator
TWEETER:
K-74-K 1" (2.54cm) Phenolic dome compression driver
HIGH FREQUENCY HORN:
90°x40° Exponential Horn
HF CROSSOVER:
1800Hz
WOOFER:
Two K-8-K 8" (20.32cm) Poly ICG cone active / KD-12 12" (30.48cm) Fiber-composite cone passive
DIMENSIONS:
24.25" (61.6cm) x 15.75" (40cm) x 10.75" (27.3cm)
WEIGHT:
40 lbs. (18.2kg)
ENCLOSURE MATERIAL:
Medium density fiberboard construction (MDF)
