Thank You for the response.
I thought more about it and came to a similar conclusion about seeing if it was limited to a particular speaker and it appears that the center speaker is causing the issue.
So either the speaker is at fault, the speaker connection or the wire or faceplates in the wall. I'll work on determining which of those are the problem.
If it is the speaker, can it be fixed or do I pretty much need to buy a new speaker? Same question for amp.
Thanks,
Fu-Tung
You could temporarily connect your left speaker to the center channel and leave the left disconnected. That would help you sort out if you have a short in the speaker or the wiring.
I think you're on track to double check your wiring. Use a magnifying glass to look for loose wire strands. Or better yet, disconnect the wires, tin them with solder to prevent loose "wiskers" and connect it back. If you have wires wrapped around binding posts on the front of the plate, install banana plugs. They don't short out and they are easily disconnected.
If the speaker is damaged, there are specialty shops who repair speakers. There aren't many though, so that could be a problem. Around here, I know of only one who could do this work and he is expensive. You can also mail order a replacement driver and repair it yourself. You would have to try to match up the specs. That can be tricky. The entire design of a speaker, it's enclosure and crossover is an integrated design.
To have an amplifier repaired, you would want to look for support from the manufacturer. If it's older or lesser known, you might have luck if you find a ham or electronics enthusiast to work on it.
