SOLD-------
KEF Q6c Center channel- Mint Condition
I am parting with this nearly new center channel with original box and manual. Still under warranty for four more years. Only used for 5 months and it has been in the box since June 06.
This is high end British equipment at a very reasonable price. Excellent match for KEF's Q, iQ and KHT 2005 serise among others. Works great to beef up Circuit City's KEF Eggs (KHT 2005.2 system). I have gone with the iQ6c center for my KEF iQ9 towers.
At the heart of the new additions to the renowned Q Series is the latest in the highly successful line of Uni-Q driver arrays. A 130mm die-cast chassis houses the long throwcone and coincident mounted 19mm aluminium dome HF unit for true point source reproduction. Combine the excellent off-axis dispersion characteristics of Uni-Q with the magnetic shielding of the drive units and you get a speaker which is much easier to place in the room and one which alleviates the traditional sweet spot found with 'ordinary' speakers.
By utilising an identical Uni-Q array in the Q6c centre channel. an even tonal balance is obtained throughout the soundstage when combined with other models in the range. Configured for bi-wiring. as are all the new Q Series products. or even bi amplification. The Q6c has the power and presence to bring your home theatre to life.
Q6c Specifications
Design 2 way bass reflex
Drive units LF: 130 mm (5.25") Uni-Q® with
HF: 19 mm (3/4") aluminium dome
Frequency response at 15°
horizontally off axis ±3 dB 50 Hz - 27 kHz
Crossover frequency 2.8 kHz
Amplifier requirements 10 - 100 W
Sensitivity (2.83V/1m) 89 dB
Maximum output 109 dB
Impedance 8 Ohms
Magnetic shielding Yes
Weight 4.1 kg (8.6 lbs)
Dimensions
(H x W x D) 165 x 434 x 215 mm
6.5 x 17.1 x 8.5 in
Finish is beautiful Dark Apple
Thanks for looking and I'd prefer pay pal. Priced very reasonably at $89 + actual shipping. Fed Ex ground.
Paul
