KEF Model3 Satellites $120/pr
sholling
sholling
Ends 3/29 and includes free shipping. I have no idea how they sound but they might be interesting to KEF aficionados. I'm curious if anyone has heard these.
Driver Units
100mm (4in.) Uni-Q arry with 19mm (0.75in.) aluminum HF 2 x 75mm (3in.) LF
Frequency Response
80Hz - 27kHz
Nominal Impedance
8 Ohms
Sensitivity
88dB
Newegg.com - KEF MODEL3BL Pair Two-Way Closed Box Satellite Speaker Pair
KEF MODEL3 Home Audio Speakers combine KEF’s proven Uni-Q ‘point source’ driver array from the award-winning KHT separates system with a unique new application of NXT flat panel technology, delivering detailed 3D surround effect from just two speakers positioned at the front of the room, with no need for speakers and cables behind the listener.
Like all great ideas, the concept is simple. The vertical NXT flat panels behind the main arrays create virtual rear effects speakers, while the Uni-Q drivers create a perfect‘phantom’ centre speaker right in the middle of the screen – just like the movies. The effect is certainly impressive, with pin-sharp dialogue and vocals appearing to come from the performers’ mouths as if they were physically there. The same is true for rear effects – with your eyes closed, you’d swear the sound was coming from behind you. The acoustic illusion of all three virtual speakers is accentuated by the Uni-Q driver configuration, which spreads the sound image over a much larger area than a conventional speaker.
