Kef Ls 50 Meta vrs Martin Logan Motion 40
N
Nana A.
I am contemplating on changing my Speakers.I dont know if it is downgrade or upgrade.I want to replace my Martin Logan motion 40 and the Slim xl with the Kef Ls 50 Meta .All suggestions are welcome.Once again thanks for the help.
L
lp85253
hard to tell if that's an upgrade.. your ears will know
Different designs, hard to say what you might prefer but would think the smaller Kef speaker may struggle depending on room size. Are you downsizing speakers for a reason?
Pogre
Pogre
2 completely different speakers with different strength/weaknesses. This truly is a "get out and listen to them" situation. By all accounts they're both good speakers and the Metas are a cool concept. I wanna check those out.
I don't know if the KEFs will be "better", but I'll bet different enough to feel like you changed something. You have a local B&M with a return policy? I'd say it's worth a test run at home if possible.
N
Nana A.
I just dont like the sound of the Martin Logan.It is too warm.It might sound weird but i like my speakers bright.Also i dont want big speakers anymore.But i am more concerned about the sound.
I'd definitely do a comparison, in your room if you can, first in any case before making changes. No experience with either speaker other than what I've read about them from users, both have their fans but is there a particular reason for Kef vs other brands?
