CraigV
CraigV
I have finally found the pair of speakers I have been looking for. I’ve never been satisfied with the standard 3 speaker front setup of a typical home theater. No matter what speakers & positions I have tried, I have never been happy with the way the center channel speaker integrates with the front left & right. The center speaker always draws attention to itself, making it so the dialog & action from the center channel comes from the speaker, and not the center of the screen. I tried going the “phantom center” route, but no matter how I positioned the left & right speakers, moving off axis always produced drop outs in the frequencies being reproduced. This is common for speakers where the tweeter is physically positioned above or below the woofer.
I had heard the UniQ speakers from Kef address this problem by mounting the tweeter in the center of the woofer, so all the frequencies being reproduced all come from the same source. I also read some reviews that suggest the smaller bookshelf sized speakers had a problem with the sound being muddied, as the low frequency driver also acts as a wave guide for the high frequency driver. One reviewer suggested that Kef overcame this issue by designing a “2 ½” way speaker. Built into a larger cabinet for added bass extension, the woofer covers all bass frequencies up to 250hz and then crosses over to the UniQ array, alleviating the lowest frequencies & easing up the duty of the UniQ driver.
I had some trepidation about metal tweeters from other speakers I had listened to, let alone two metal drivers working so closely together. After reading some positive reviews on the IQ7, I found a local dealer who had them on display, and went to give them a listen. I liked what I heard, and found a pair on sale for a steal of a price, so I pulled the trigger and got a pair.
After giving them a one week break in period, I sat down to give them a serious listen. I used the spikes they came with, and mounted them on some wooden stands I had made, so the tweeter was ear level. After experimenting with toe-in, I was able to achieve a stable image all the way across the soundstage, even off center. Voices & sound effects panned seamlessly across, above & beyond the speakers with ease, just as I had hoped.
What I didn’t expect was what I heard as I listened longer – neutrality. I have had/tried out some mid to high end speakers, including Paradigm, Dahlquist, Apogee, and even experimented with some DIY designs of my own, but was never satisfied. One speaker might have good tonal range, but poor imaging. Another might have good imaging, but emphasize & color part of the tonal range. The IQ7 speakers add no resonance, coloration nor anything to the music & sounds reproduced. They image is solid, and the soundstage is wide, deep & tall, but again, not exaggerated. With these speakers, the quality of the source material, the recording, the mix…everything is as it should sound. The word I like to use is “organic” even when the sound is artificially produced, these speakers neither take away nor add anything to the mix – they let the sound come through un-altered.
I believe these speakers offer all the hallmarks of what a good speaker should be, and for the price paid they are an outstanding value.
Associated equipment: B&K Sonata Series Video 5 Amplifier, Rotel RSP-1066 Pre/Pro, Panasonic BD-55 Blu-Ray player, Audioquest cables.
CraigV
roshi
Hey,
I was wondering if you also bought the iq6c center from KEF. I'm interested but need to know if I can wall mount it. If not do you maybe have an idea about a different KEF speaker that's wall-mountable that i can substitute and still use the iq7s as mains and the iq8s as surrounds...
Thanks a lot!
lsiberian
lsiberian
Hey,
Thanks a lot!
You can wall mount it. It's 20lbs so you will want a good sturdy mount and you will probably need a stud to mount it on.
You could also use the iQ2 but it's not nearly as good. the iQ6 is one of the best centers on the market.
Get a iQ6 and this below.
http://www.jr.com/bt15-center-channel-speaker-bracket/pe/BTH_BT15_hy_BK/
You will need to find two studs to mount it, but it will hold your speaker.
G
GomGom
Do you mind if I ask how much you paid for the IQ7? I'm looking forward to purchase that too...
G
GomGom
What receiver do you match that speakers with?
I hope you don't mind me a newbie asking this. How do you position iQ7 compare to other products such as NHT and Paradigm on the same level?
G
GomGom
And how does it perform compare to Monitor Audio RS6 and Rega R3?
roshi
thanks for the replies,
back to the original thread for a second... What do you think about substituting the iq6 with a KHT6000 center. I just hung my lcd and really don't want some kind of center stand on the floor. I also think that it will probably look bad to hang the iq7 with those wall mounts mentioned above. Anyways, what do you think about the kht6000 to match with the iq7. Both have the Uni-Q Array, even though the kht6000 has only 3" woofers... it would definitely look a lot better.
thanks again.
CraigV
CraigV
I use a Rotel pre-pro RSP 1066 and a B&K Sonata 5 channel amp. Audition all the speakers you're considering, and pick the one you like best
thanks again.
No, they will not be timbre matched, and the sound difference would be too obvious
