Keep The Klipsch or Go with SVS?
Assumer
Hey guys.
Currently updating my system. Started with new speakers (PSB X2T) and a new receiver .(Yamaha 3050) I currently own a Klipsch RSW 15. I was wondering if the SVS PB-2000 would be an upgrade to the Klipsch? Started looking due to my wife asking why all my stuff was black but the subwoofer was brown. Read the SVS review on Audioholics and they seem to love it. Any thoughts? Thanks
crossedover
crossedover
What is your room size and total budget? And yes the PB would be an improvement below 50hz for sure.
Assumer
Well, room is 21x24x10. Budget is $800-$1000. Really have nothing to go on being the Klipsch is the only subwoofer I have owned.
crossedover
crossedover
Either the pb or the hsu is an upgrade, with shipping the hsu is at the top of the budget, but IMHO would be better with your room
Assumer
Thanks for the reply. I will check into the hsu and make a decision.
Assumer
So Looking at HSU they have the ULS-15 MK2, VTF-15 MK2, and VTF-3 MK HP all within the price range. Any thoughts on the differences? Is one typically considered best of the three?
crossedover
crossedover
the vtf 15 will meet your needs based on room size vs their performance
crossedover
crossedover
If your listening room is not really big, I would consider a pair of the SVS SB12-NSD while they are on sale!
http://www.amazon.com/SVS-SB12-NSD-400-watt-Controlled-Subwoofer/dp/B009F8Y7SO/ref=sr_1_1?ie=UTF8&qid=1448842609&sr=8-1&keywords=svs+sb12-nsd
They are pretty compact compared to the ported subs and most people find the WAF of two smaller subs is better than one (and especially two) large ones.
For overall sound quality, I generally consider having a second sub more important than having the output to shake my guts for HT. (but the SB12-NSD isn't a weak sub either.
21x24x10 room
Assumer
Ok. About to pull the plug. Between the SVS and HSU is one more musical than the other❓
shadyJ
Speaker of the House
Staff member
I would go with the Hsu subs, they will have a lot more dynamic range, and hence less distortion and compression.
Also, I think the phrase you are looking for is "pull the trigger". "Pulling the plug" would mean you are about to shut something down.
Assumer
Ha! Yes, as soon as I posted I thought wrong phrase. That's what happens when you are hanging with Mr. Hornito.
shadyJ
Staff member
Nice, let us know how you like it when you get it going!
KEW
KEW
Good call! I think you would have been happy with either, but the Hsu represents better value, IMHO.
Assumer
Will give you guys an update. Should be her Thursday. Thanks for all the input.
Assumer
Thanks for the HSU suggestion. This thing is killer. Only negative is I had to carry it into the house alone.
