Status
Not open for further replies.
Seth=L
Seth=L
I am selling my JVC RX-DP9VBK 7.1 Home Theater receiver. Comes with remote and manual. It does process DTS-ES and Dolby EX material (does read Dolby EX flags). Does not have Dolby Pro Logic II or IIx movie, music, and game modes.
Pictures
The RX-DP9 is a THX Select certified Receiver, which has 5 independent amplifiers built in along with 7.1 output so you can take full advantage of the THX surround EX decoder. The zero interference technology eliminates any interference within the receiver to produce exceptional sound quality. To improve CD and DVD sound reproduction the RX-DP9VBK uses a C.C.Converter and a 24 bit/ 192kHz P.E.M. D.D. d/A Converter to recreate the sound as it was originally intended. This receiver is packed with features which makes it a world class receiver.
Features 120 watts x 2 min. RMS, both channels driven into 8 ohms from 20Hz to 20kHz with no more than 0.02% THD, 120 Watts x 2 min. RMS, driven into 4 ohms, with no more than 0.07% THD. 4 ohm Rated (FTC)
100 watts x 5 min. (2 Front, 1 Center, 2 Rear speakers) RMS, into 8 ohms, 1kHz, 0.2/0.7% THD
DVD Multichannel Audio Compatible (6 channel inputs and 5 separate amps) for connection to existing and future multichannel sources such as DVD Audio
LCD multi-brand A/V-CATV-DBS remote control.
Dynamic Super A amplifier
C.C. Converter (main channels) provides better resolution ,enhanced ambience, and greater depth by eliminating distortion known as jitter and ripple
1-bit P.E.M. D.D. Converter greatly enhances signal to noise ratio and dynamic range (192kHz/24-bit, 7.1ch)
Dolby Digital/DTS decoders built-in for theater quality surround from digital sources
3 Band Parametric EQ for all 7.1 channels
Digital Acoustics Processor (DAP), with 12 modes DSP
3D-PHONIC Virtual Surround Sound creates dramatic home theater sound with just two front speakers
Text COMPU LINK will transmit text data carried by media like CD-Text and MD to display on your receiver and a television
Line Direct for pure audio sources like CD
AV COMPU LINK provides simple one touch operation between your JVC audio and video components. For example, pop a pre-recorded VHS tape into the VCR and it will automatically power up your receiver and your television and then turn them each to the proper inputs.
Enhanced COMPU LINK Control System
On Screen Display simplifies control by allowing you to choose options from your television screen to operate your receiver
Line level Sub Out
Loudness switch, Balance, One-Touch Operation, Velocity-Sensitive Rotary Encoder Volume Control
9 Audio Inputs
4 Audio Outputs
5 Composite Video Inputs (1 on Front Panel)
TV Sound
HD(35mHz) component outputs for chrystal clear video switching with no signal loss: 2 In/1 Out
Front A/V Input with S-Video (Gold Plated) for the convenience of hooking up any A/V source quickly and easily such as a camcorder or video game
7.1-Channel Pre-outputs for added flexibility in creating a high end A/V system
1 Assignable Coaxial Digtial Input that you can designate to any digital source
5 S-Video inputs (1 on Front Panel)
3 S-Video outputs
3 Composite Video outputs
2 Main Speaker Terminals
Surround Speaker Outputs
Center Speaker Terminals
2 Surround Sound Speaker Terminals
15 AM and 30 FM station memory
2 Year parts and labor warranty
Weight: 49 lbs
Width: 17 9/16-Inches
Height: 7-Inches
Depth: 18 3/4-Inches
Multi-Way Banana Type binding posts for easy speaker connections (Main1/Main2/Center/Surround/Surround Back)
High-Rigidity Z-Chassis
Dolby Pro Logic in Full Digital Processing
3 Optical Digital Inputs
1 Optical Digital Output
I am asking $400+shipping, I would like to hear offers via PM as well.
Seth=L
Seth=L
Bump.
Make me an offer!
This is your chance to get a bold powerful piece of equipment, it is overkill for my apartment (everything I have is overkill for my apartment;)).
I accept money orders by the way.
Status
