just got a active subwoofer
turnsignal
just got a active subwoofer, and was not positive on the correct hookup?
i was gonna run a rca cable from my Denon AVR3600 subwoofer hookup on back to the subwoofer labeled low level input. does this seem correct. thanks
turnsignal
how do i check if this sub is working? i'm not hearing anything different
turnsignal
there is a red and white input? please inform me
U
Unregistered
Guest
Make sure you connected to the subwoofer 'pre-out' on the receiver (sometimes labeled LFE), not the subwoofer in in the 5.1 analog input section (if that receiver has 5.1 analog inputs).
You only need to connect to one of the sub's inputs. Usually the L.
Make sure sub is set to 'on' or 'yes' in the receiver's setup. Some subs have auto-sensing inputs and turn on when a signal is received. Try turning up the volume on the sub or the subwoofer output level in the receiver's speaker setup menus.
Use a mode that uses the sub, like plain old stereo for music or put in a movie.
