Vipper III said:
I just bought the LVM-42W2 yesterday, but I have a question. I've read that if the LCD's internal scaler/de-interlacer is good, that an upconverting DVD player is probably not necessary. Is this true? The product review was quite informative, but I'm mainly curious as to whether a non-up-converting DVD player will look just as good. Thoughts?
Thanks!
Some TVs do a MUCH better job of upconversion than some DVD players, and some DVD players do a much better job of upconversion than some TVs. So which you should use depends on the particular equipment we are talking about. However,
ideally, you will use a DVD player that sends the signal digitally to the TV. The reason being, of course, is that the signal on the DVD is digital, and if you convert it to analog to send to the TV, and then convert it back to digital for your digital TV, you have some conversion that isn't going to do the signal any good. But, again, if the TV does a better job of upconverting, you are better off using its upconvertor instead of the one in your DVD player, and the back and forth conversion between digital and analog can make less difference.
