You can use regular wires. If you wall mount this speaker, you likely won't be able to fit plugs into the back, but if you are shelf mounting it then you will likely find it much easier to use some banana plugs of some sort.
I really like my Mythos 8 speaker. A good low-profile speaker with good output.
