what do you mean? I already told you all the JL would care to share with the public. Different motor and motor characteristics, different suspension, etc.......they all lead to different T/S parameters, and ergo a likely different SQ. If you want exact numbers on how the Le or Qtc changed, you need to call JL themselves and perhaps you'll get lucky and they will share it with you.
Chris(Wmax),
What are your thoughts on using the JL audio subs 12" and 13.5" with the EP2500? What about the fact that they are 3 ohms nominal 2.47 and 2.41 ohms(Re) DC resistance respectively? The EP2500 is only good to 4 ohms mono is it not? This was the issue I have run into in looking at constructing my own.
just add to Chris' excellent post, I've used the EP2500 numerous times in my DIY subs. They great amps for the price, no doubt. However, as mentioned earlier, I would consider one of crown's or QSC's mid to higher end offerings if you going down this route.
The EP2500 is a cheap clone of the RMX, QSC are using better quality parts.
EP2500 pic
http://home.pacbell.net/lordpk/proamps/EP2500-1.jpg
RMX2450 pic
http://home.pacbell.net/lordpk/proamps/RMX2450-1.JPG
Which parts do you consider better quality?
re: transformer size. The newest pic of the EP2500 shows a transformer
size that appears to be the same as RMX2450. I had doubts last year because
I saw an older pic.
re: warranty
A good warranty and good service to repair your amps is a good thing.
Some will say you can almost get 2 EP for the price of one QSC that's right because you need a spare just because you are never sure when you gonna hit the power switch what gonna happen.
The EP and RMX will have the same chance of failure.
For the XLS series the picture are from the B series the new D series as real heatsink
Post a pic of the D series XLS guts
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I doubt Crown made any upgrades to
heatsinking because they *still* don't rate those amps for 2 ohm stereo
nor 4 ohm bridge mode, lol..... They could easily if they had any good heatsinking
inside. You'd think if they did heatsink upgrades they'd change their specs for
the better..
http://www.crownaudio.com/amp_htm/xlsspec.htm
XLS602 heatsinking. lol .. ware..da beef?
http://img337.imageshack.us/my.php?image=picture009gs9.jpg
which leads us to:
What is the difference between the XLS 602A amp. and the XLS 602D amp?
Bridge-Mono switch, re-laid out circuit board, new front panel, more front panel metering and a little more output power.
David Glass
Applications Support Engineer
IQ Systems/Engineered Systems/Touring
Crown International
http://www.crownaudio.com/forums/index.php?showtopic=1429
XLS402A: Stereo Mode Power Rating: 8 ohms: 260 watts, 4 ohms: 400 watts, 2 ohms: 570 watts, Bridged Mono Power Rating: 8 ohms: 800 watts.
XLS402D: Stereo Mode Power Rating: 8 ohms: 300 watts, 4 ohms: 450 watts, Bridged Mono Power Rating: 8 ohms: 900 watts.
Interesting that the original was rated for 2 ohms/ch, but not 4 ohms bridged.
Someone must have made a marketing error.
so what does all this mean? It means that the EP2500 is a fantastic amp at $300, and should be in your list of amps to make this fathom clone. However, to really push the 13W7, if you can muster the cost, there are better options in Crown and QSC.
