JL audio 12W7 &Crown XLS1500 bridge mono 1500 watts in a 18" h x 18" d x 48"w porting
jesussavedjoe
I trying to figure out porting and adequate bracing for a JL12W7 and box in exterior box size of 18"H x 18" D x48"w with double walled front 48" wide where subwoofer is mounted. I am open to slot porting or multiple square ports if performs better
What do you think of this post?
What I would do is around 200L tuned to 17hz. A 2nd order HPF cented around 16hz will do. A slot Vent would be something like 10 x 3.5 x 41 inches or so. This will allow you to throw around 1000w at it for roughly 110-115db @ 1m Rolloff should be smooth towards 20hz and sharp below that.
What do you recommend ?
Porting and any other recommendations
Ready to Build , your input would be helpful
thanks
annunaki
annunaki
Moderator
Ideally with a 12W7 you will want somewhere around 45 in^2 of vent surface area if memory serves me correctly. That puts your current design around 10in^2 short. That amount (45in^2) will keep your vent velocity below 17m/s.
Without modeling your design I am just going from memory however.
Passive radiators may be a better option as proper vents for a 12W7 displace some serious volume.
jinjuku
jinjuku
Moderator
The XLS DriveCore has a 12dB / Octave roll off at 20Hz...
