redd454
just got a jbl es250p, 400 700watt peak powered home subwoffer, i noticed plus the lfe, it has banana input's rated at 150 watt's, i normally use lfe, has anyone gotten better results switching to normal, and using the receiver to these inlets?
redd454
thank you, i always have, just wondering, if i've been missing something
redd454
is is allright to use my subwoffer with an equlizer, i have been, and it seems ok?
BMXTRIX
BMXTRIX
Nobody that I know of does this. But, if you have an equalizer designed specifically for low-frequency usage, then it may be fine. Not sure what proper equipment you are using to tune the room.
redd454
my equlizer, is a yamaha eq-500?- should i remove it from system? howevr everything sounds great, in analog, my subwoffer's seem to perform well
