Jbl Studio L Series - What About Performance??
avliner
avliner
Hi all,
does anybody has any comments regarding to the new STUDIO L SERIES from JBL? Any comments will be appreciated.
Cheers / Avliner.
mike c
mike c
without grills, they look cool from afar. but close-up, they look cheap (not quality, just looks)
the studio L's apparently reach 40khz? because of its ultra-high freq tweeter (it has 2 tweeters)
http://www.jbl.com/home/products/series.aspx?SerId=SLS&Language=ENG&Country=US&Region=USA
I never bothered to listen to them, because I just bought my set when they came out here, and I DID NOT want to get buyer's remorse.
although if you put much weight in my audio salesman's opinion, he said he preferred the Infinity Beta series over this JBL studio L
avliner
avliner
As an additional info, I've, I've found the review on Sound & Vision Magazine site and the Studio L range seems to be pretty good.
There's one thing that pretty much reinforces the above review; i.e., although the L/R/C speakers shows an impedance of 8 ohms on paper, the bench results has proven that they go further down to 3.2 - 4 ohms load instead!!
For that reason only it makes me believe that the Studio L's are pretty damn good ones and most definitely worths an audition!
Cheers / Avliner.
Impedance varies with frequency, so an 8 Ohm speaker going to 3.2 Ohms is not unusual. The former Studio line was pretty good, and though I have not heard these, I'd expect them to be at least as good as those, though I haven't heard much discussion about them.
jeffvee
Studio L 's
I currently have some of the Studio L series speakers and they sound very very good.
I have the Studio L8400 600 watt Subwoofer, as surrounds I have the L810's.
For HT, these are excellent sounding speakers for a home application. My room is 14 x 19 and I am very pleased with the performance.
I only listen to music in 2 channel with the sub ,and it too sounds amazing.
Hookup:
Harman Kardon AVR630
JBL E 100 main fronts
JBL EC35 Center
JBL Studio L8400 Sub
JBL Studio L810 rear surrounds
avliner
avliner
Jbl Studio L - Review
Hi,
thanks for the feedback, jeffvee.
On the review (Sound & Vision), the studio's have been highly regarded.
They do emphasize, however, that some caution must be taken when matching those with a receiver, due to their impedance ( basically the fronts & center channles ), as they go down to 3,2 Ohms (they're all spec'ed at 8 Ohms, though).
Have heard a lot of people saying that the higher JBL ranges are pretty damn good ones ( even those who doesn't like them...).
By next week I'll try to audition them somewhere in Orlando, FL.
Cheers / Avliner.
