JBL Performance Series PT 800 and PC 600 new in box for sale
Hasselhof
JBL Performance series
For sale : 2 JBL performance PT800 black and one JBL performance PC 600 center speaker. Price of 900 dollar is pr speaker. I will sell the Center speaker PC600 separate, but the pair of PT800 must go together.
All the speakers are new in box, never opened never used. All are in black finish.
As these speakers are discontinued from JBL this might be the last chance to own these speakers factory new.
I ended upgrading to the Array 1400 speakers before ever opening and hooking these speakers up. Since my audio-room was under construction for almost 2 years. I considered using the pt 800 for rear speakers but have bought jbl 8340 instead. So these great speakers can be the joy of someone else.
Speakers located in Elkhart Indiana zip 46514
will ship world wide
From JBL :
PT800BLK-Z
Mfg Model: PT800BLK-Z
One of the basic building blocks of the Performance system, the PT800 3-way, 8-inch tower satellite can be used in one of three configurations: docked with the PS1400 powered subwoofer to function as an integrated floorstanding loudspeaker system; stacked with the PS1400 but receiving its signal directly from the receiver or amplifier; or mounted on a wall, in a corner or on a bookshelf. Use as many PT800s as are needed for a premium two-channel system, or a 5.1, 6.1, 7.1 or higher home theater system. Black.
3-Way 8-inch wall-mount corner-mount or bookshelf satellite speakers
Recommended Power
10 - 250 Watts Per Channel
Frequency Response
80Hz – 22kHz
Impedance 8 Ohms
Maximum Recommended Amplifier Power 50 - 250
Impedance 8 Ohms
Sensitivity (2.83V @ 1m) 91dB
Frequency Response 80Hz - 22kHz (-6dB)
Crossover Frequency(ies) 800, 3500
High-Frequency Driver 1-inch pure Titanium dome with rubber surround, shielded, with EOSTM Waveguide
Midrange Driver 4-inch Titanium inverted dome with rubber surround and cast Aluminum basket, shielded
Low-Frequency Driver Dual 6-inch Titanium-alloy inverted domes with rubber surrounds and cast Aluminum baskets, shielded
Dimensions
(H x W x D) 11-5/8" x 26-7/16" x 7-1/4" plus grille
(295mm x 672mm x 184mm)
Weight 32 lbs. (15kg)
towerhill
still have them?
From JBL :
PT800BLK-Z
Recommended Power
Frequency Response
80Hz – 22kHz
Impedance 8 Ohms
Impedance 8 Ohms
Dimensions
do you still have them and if so haow mucha are you asking?
Mkusweat
Jbl
Hello;
Do you still have those JBL speakers for sale?
Let me know
Andy Martin
