Will I be able to power JBL L150 with 100 wpc? Speakers are rated at 300 watts.
I ifsixwasnin9 Audioholic Mar 1, 2022 #1 Will I be able to power JBL L150 with 100 wpc? Speakers are rated at 300 watts.
lovinthehd Audioholic Jedi Mar 1, 2022 #2 The speakers would work with less than one watt....just depends how loud you want to get or how much overhead you want in reserve....but they're relatively sensitive so likely 100wpc would work just fine. Perhaps try this http://myhometheater.homestead.com/splcalculator.html ps the max wattage rating of a speaker is more a limit than any sort of requirement....
j_garcia Audioholic Jedi Mar 3, 2022 #3 That is the wattage peak they can handle, not how much they require to play sound.
