No mystery, just set the level as you would for any off-the-shelf powered subwoofer, e.g. for a proper blend with the mains. If you set it to high you’ll know because all you’ll hear is bass! Just as with any other sub.
Regards,
Wayne A. Pflughaupt
I appreciate the response.
After further messing around with it, I have to sort of disagree about the simplicity.
I turned the gain knob up to max and its not exploding. It seems like some combination of gain and the volume control on the receiver affect the output, although it seems there are more factors than that. I am going to be owning this piece of equipment for quite some time and I'd like to actually know how not to blow the thing up given that I'd like to fiddle with it and set it to the best possible settings.
The amp is rated for 650 watts per channel at 4 ohms. It is a single voice coil sub, so I have at most 650 watts that could be making it to the sub.
The sub, as I said, is 4ohm single voice coil 350 watt rms.
Is there a straight forward way to calculate the wattage that is being delivered to the sub?
