One of these? Do you have any model numbers on cabinets, drivers or the mixer? Likely they're high sensitivity speakers and won't require a lot of power to get to deafening levels, a normal receiver should be fine; I take it you don't have a receiver, or an integrated amp or a pre-amp/amp combo of your own? Speaker wire
article here
What's your aim, a little home theater and/or for music? What sources do you want to use (cd, computer/streaming, radio, etc ).
lovinthehd - thanks for your reply; hope I clicked the correct Reply button.
Thanks also for the link to obsolete JBLs. I think these were custom built (not sure); they have three speakers in them which I can view through the rugged screen: 1 - 2370A horn, 1 - midrange?, 1 - 15" woofer? Plus, there are four cutouts for very tiny speakers (tweeters?).
The speakers and electronics are in storage:
Drivers I don't understand?
No numbers on cabinets; they are carpeted in gray.
Mixers: one in my office now is a YAMAHA MG102c. Others, I will look on storage.
Amp/receiver: there is a rack style AMP? or Receiver? Will go to storage tomorrow to see exactly.
My aim is to sell these; but I would like to demonstrate to a prospective buyer that they work. In the past, I have observed two in use inside a home. I thought they were overkill to be in a living room so the family member demonstrated that they could produce pleasing music of a movie score at low volume levels. Unfortunately, I did not observe his setup.
I do appreciate your feedback. And, can I post images in these posts?
