Hi Guys,
I need suggestions, alternatives, advice on whether i should get this set?
Anyone of you having this baby? I've read a few reviews and was thinking to seek advice from this great community. Price comparison wise, is it worth it?
Frequency Range (-10 dB) : 60 Hz - 19 kHz
Frequency Response (±3 dB) : 75 Hz - 17 kHz
Power Rating : 350 watts continuous
pink noise
1400 watts peak
Sensitivity (1W/1m) : 99 dB-SPL half-space / wall-mounted
97 dB-SPL free-field
Maximum Peak SPL : 130 dB/1m
Nominal Impedance : 8 ohms
Hor. Coverage Angle (-6 dB) : 100° averaged 400 Hz to 12 kHz
Vert. Coverage Angle (-6 dB) : 80° averaged 400 Hz to 12 kHz
Directivity Factor (Q) : 7 averaged 400 Hz to 12 kHz
Directivity Index (DI) : 8.4 dB averaged 400 Hz to 12 kHz
Crossover Frequency : 1.4 kHz
High Frequency Contour : ISO2969 Curve X surround contour
Polarity : EIA (Positive voltage to RED terminal gives forward cone motion)
Low Freq Transducer Nominal Diameter : 250 mm (10 in)
64 mm (2.5 in) voice coil
High Freq Transducer Nominal Diameter : 25 mm (1 in) exit
38 mm (1.5 in) voice coil
Downward Firing Angle : Nominal 20° when mounted flush on back panel
Enclosure Material : Textured Black H.I.P.S. Plastic
Grille Color : Black
Input Connectors : 5-way binding posts
Dimensions (H x W x D) : 457 mm x 457 mm x 260 mm
(18 in x 18 in x 10.25 in)
Net Weight : 9.5 kg (21 lb)
Yeah these are the specs. Sorry for the copy paste though. If you have promos or wherever in California area. I'll be following this thread closely so thanks for your feedbacks or inputs. Appreciate your time looking at this thread. Cheers.
