Heads up, Jamo fans!
Jamo has launched their new Concert Speaker Series with new and improved technologies. Their flagship model of the series is the C-109 Floorstanding Loudspeaker.
This is a 3-way bass reflex design that features two 7-inch woofers, a 7-inch midrange driver and a 1-inch decoupled tweeter. It includes redesigned silk-dome tweeter diaphragms, extra large surrounds to help offer lower distortion and greater high frequency extension. Also we will find a new hybrid composition conical cones that, according to the company, combine the stiffness and strength of aluminum or titanium with the transient response and smoothness of wood fiber. It is available in high gloss black, high gloss white and walnut veneer finishes with satin painted MDF baffles. Check out the following list of features and specifications.
FEATURES:
- All-new Long Displacement Surround (LDS) design for woofers and midrange drivers that deliver improved low-frequency response that leads to a more natural, open sound.
- Improved Anti-Diffraction WaveGuide (ADW) technology that provides improved off-axis response with more uniform high frequency extension for more immersive and impactful listening outside of the sweet spot.
- Hybrid Composition Conical Cone (HCCC): Provides the stiffness and strength of aluminum or titanium, with the transient response and smoothness of wood fiber.
- Tweeter Distortion Reduction (TDR): Provides lower distortion, greater high frequency extension and smoother high end.
- Redesigned silk dome tweeter diaphragms with extra-large surround that lower distortion and enable greater high-frequency extension.
- One 1-inch (25 mm) silk dome decoupled tweeters with Anti-Diffraction WaveGuide and Tweeter Distortion Reduction.
- 7-inch (178 mm) Hybrid Composition Conical Cone midrange driver with Long Displacement Surround technology
- Two 7-inch (178 mm) Hybrid Composition Conical Cone woofers with Long Displacement Surround technology.
- Aluminum center-plug: Eliminates cone breakup for faster attack and increased vocal clarity.
- Additional voice-coil cooling reduces power compression.
- Dual, 5-way binding posts: Allows bi-wiring/bi-amplification with multiple connection options with wire up to 12 gauge (AWG).
SPECIFICATIONS:
- System Type: 3-Way Bass Reflex.
- Impedance: 6 Ohm
- Tweeter: One 1-inch
- Midrange: One 7-inch
- Woofers: Two 7-inch
- Product dimensions (HxWxD): 44.6" x 9.2" x 16.4".
- Frequency Response (Hz, +/-3dB): 30Hz - 27kHz
- Power Handling (Watts Long/Short Term): 200W / 400W.
- Sensitivity (dB, 2.8V/1m): 89dB
- Finish High Gloss Black, High Gloss White, Real Walnut Veneer.
- Minimum Amp Recommended: 75W
- Weight: 80 lbs.
Price: $3,500/pair.
What you say? Do you like it?
