Its the Magnepan MMG or me
yannaros
yannaros
Hello
I just received my magnepan MMG today and hooked them up
First impressions
1. No bass I dont except too much bass anyway
2. Too high mids and highs
I use a monster XP monster cable for speakers and I was wondering maybe its the wire since that one doesnt give inaff bass and emphasizes the highs.
Please help. I know these speakers are nice according to the reviews and opinions. What am I missing
My system consists of:
Turntable Thorens TD 166 MK VI
DVD Rotel RDV 1045
Tuner Rotel RT 1080Pre Amp Rotel RC 1082
Power Amp Rotel RB 1080
Power Conditioner Rotel RLC 1040
Magnepan MMG
HDTV Panasonic TH-42PZ77U
Monster Cable Interconnects
Monster Speaker Cable XP
rnatalli
Maggies are picky about placement. Try moving them around a bit and see what happens. If all else fails, it's possible that you like me don't like Magnepan sound. Are you using any subwoofer?
markw
They are an acquired taste.
I started with MMG's and if all you've ever lived with are monkey coffins, there's an adjustment period.
First off, the don't have a lot of bass. ...never will. But, what they can't reproduce they tend to ignore. That makes it easy to run a powered subwoofer with them. Simply run both full range and use the xover in the sub as a low-pass filter set tho where the MMG's start rolling off, say around 70 hz or so.
Second, they like room, lotsa room. You have to get them a few feet from all walls. Even then you're gonna have to play with toe-in to get the best imaging.
Finally, they do like power and you're fine there, but no matter how much power you throw at them, there will never be a lot of bass. Even then, it's possibe to "fart" them out if you try to push too much power into them. You'll hear it when you cross that bridge. They start to sound congested and nasal. Remember, they are entry level planars.
but, once you dial them in, you'll get imaging like you've never heard. ...and the larger maggies afre even better at conveying an uncanny spaciousness. ...oh, even though you say you don't want too much bass, a well integrated sub can do wonders.
But, like any speaker, it may not be for you. Keep all the packing stuff and, as the end of the free trial approaches and you still don't like 'em, send 'em back.
P.S. don't even think that different cables will change anything here. It's all in the room.
yannaros
yannaros
So far they have wonderful mids and highs. I am waiting for the break in period to see where they can go and maybe in the future I will go higher on maggies
One think I dont understand is my amplifier supports 4 ohms and I should hear double almost power but I dont hear it.
markw
I responded to your threat at AudioKarma since you got more responses there.
