Hey all,
I know, I know... 2022 is like going backwards in many ways.
But I'm wondering... where are the AVR's with pre-amp output for the Fronts & Center only? Don't want or need it for all channels and don't need a 9 channel or more receiver. Any 5 channel or 7 channel AVR's with modest specs and just pre-amp out for center & fronts? I see a few that are entry mid-tier with front pre-amp out, but they all seem to lack the center pre-amp out and that makes no sense to me as a home theater receiver.
Discussion:
Then again, maybe there's no point? A modern AVR can do the same job as a crippled AVR with some power amps in the 100~130 watt/8ohm per channel range, right? Do you all think its really at the 200+ watt per channel range that you need to go pre-amp and power amp for larger rooms or less efficient speakers? I probably don't even need 100 watts. Just thinking out loud and looking at what seems to be a super niche or non-existent product. For example, with fairly efficient speakers in the 89db or higher range, 50~80 watts is probably way plenty in a normal sized living room with normal ceiling height at about 7~8 feet distance to listening position. And of course, doubling the power is only +3db so going from an AVR that can do upwards of 100 watts to a poweramp that is solidly at 100~130 watts is really not doing anything at all except using more electricity and spending more money within the context of the same room and listening position. And of course then there's the idea of headroom...
So then we have the idea of a $600 receiver with $500 poweramp, versus a $1300 receiver.
Thoughts?
In my mind, I know that in a given room size with efficient speakers and relatively close listening positions, almost any modern AVR would be plenty for the speakers, especially if they're not having to perform a lot of the sub-bass as a series of subwoofers would handle that, further reducing any needs of he AVR in that way. So switching to an AVR with a poweramp setup would really produce no difference unless there was a headroom limit, but to even relieve such an issue like that, it would take tremendously more power for each +3db step. So really to make a poweramp addition worthwhile, it likely needs to be significantly more powerful than an AVR to even begin to matter.
Very best,
