The adjoining structures/walls will be acting as selective frequency resononators. In addition to adding physical decoupling by setting the subwoofers on a decoupling structure, you can isolate the frequency band(s) that are of the dominant amplitude and notch these, significantly reducing some of the frequencies without too much audio degradation. This would require:
1. Having each of you play a test CD while the other person is in their apartment and records the SPL with a sound level meter or an acceleroemter attached to a wall or floor(the SPL meter is the only practical method for you). Record the SPL values for the range of frequencies between approx. 25-200Hz, in at leat 5Hz resolution/increments.
2. Purchase and use a parametric equalization device such as a Behringer between the LFE output from your reciever and the subwoofer to effect the notching.
http://www.zzounds.com/item--BEHDSP1124P
It is a compromise for you both -- you will have to select the most problematic frequencies and reduce their amplitudes, but not so much as to be significnalty lowering sound quality. The silver lining is that if you are not already using a parametric E.Q. system to smooth room LF response, this device will also allow you to measure in room bass respnse and then notch the room specific resonances, thus you can increase sound quality of your subwoofers!
You can not appreciably reduce the main bandwidth(s) of low frequency energy with a parmateric device -- only the 'one note' type peaks that are in effect at some frequencies related to the wall/floor natural frequencies. These should be obvious -- i.e.; the 'one noted' bass sound that is typically heard in midbass/bass ranges as compared to a flat band(normal) sounding subwoofer.
-Chris
jaymzzer said:
Hey folks,
I am a bass lover. I play the bass en I like subwoofers.... BUT....
My downstair neigbours has a subwoofer too which penetrates through the ceiling. My floor vibrates and the ech of the bass in my house is horrible.
My neighboor is willing to adjust somethings to reduce the noise.
Somethings I know I could do are :
- reduce bass volume
- place a sound absorbing rug under the woofer
Do you know any other methods that will help us ??
Thanx in advance
