Is upgrade necessary?
E
EricAH916
Hi I recently started upgrading my HT setup from a cheap pioneer 12" 3way and klipsh center channel to a 5 piece axiom surround sound. M22's, VP150 and QS4s. Currently I`m using an Onkyo SR502, 5.1 AV reciever rated at 60w/channel. What kind of a difference would I be seeing if I upgrade to one producing 100-115 watts per channel?
I was looking around at maybe the Yamaha RXV659.
Channel wise I guess best would be to get atleast 6.1. I hear that the rear center is another good upgrade. Other than that, I'd also need a subwoofer preout.
MDS
The 502 is rated at 80 wpc. Simply going for a new receiver rated at 100 wpc will buy you next to nothing. The difference in max output between 80 wpc and 100 wpc is less than one decibel.
E
EricAH916
Sorry it's a 302. But either way I`m guessing it isn't a huge upgrade. The fronts are rated at 10-200 while the center is 10-400, would they benefit, mostly the center to upgrading the reciever or even using an amplifier to help power it.
jcPanny
jcPanny
Receiver options
Eric,
Your entry level Onkyo is probably capable of 30-40 watts when driving the full HT.
I think that the RX-V659 would be a reasonable power, performance, and feature upgrade. It also has pre-outs to add an external amp. I have a comparable HTR-5860 and would recommend it.
I have seen a few good deals on older models like the RX-V1600 for <$500 which include a better amp and HDMI switching.
You didn't mention a sub, so that would be an important audio upgrade for the HT.
E
EricAH916
The subwoofer is pretty much already picked out, just waiting for the paypal invoice from svsound. I'm going with a nsb12plus.
dvc dude
Considered Separates
I don't know your budget, but the Emotiva Ultra has 125x6 WPC and ships for $899 with an HDMI switch. It was reviewed on this site earlier this month. If the budget allows they have another set that has 150x7 WPC for $1199.
Good Luck
