Is Too much treble bad?
Evildude
Evildude
I have a pair of Sony bookshelf speaker (SS-B1000) hooked to a very old 100w amp, and I really like my music crisp and clear so I got the treble all the way up on the amp, will this mess my speakers up?
markw
Aside from the fact that if you play it too loud for too long the tweeters may fry, no.
Evildude
Evildude
can anyone here tell me how to setup the EQ so that I get clear and crisp sound without frying my tweeters?
lsiberian
lsiberian
What EQ?
I doubt you could fry a tweeter. Others things will likely go first.
markw
Believe me, one most certainly can fry a tweeter, particularly in consumer speakers, by boosting the highs to unrealistic levels and playing them loudly.
Tweeters don't dissipate heat as well as mids and woofers.
lsiberian
lsiberian
People do that?
I'm just still surprised people do it.
markw
People do that?
it was an almost daily occurance when Isold car stereos for Rat Shack in the early 80's. Kid swould buy these under-dash eq/amps, we would caution them about too much treble boost*, but they woud set the eq into the smily-face configuration anyway and a few days later we woud explain that the warranty doesn't incude stupidity.
if a speaker is rated at 120 watts,a and you feed 120 watts of treble, that's an ex=tweeter you've got there. It's shucked it's mortal coil.
If you've ever looked at a spectragraph of music, you'll find that most of the signal is in the ower midrange and bass frequencies. In the real world, tweeters don't need to be as robust as those speakers.
*forces the amp into clipping (12 db = 8X the midband power) and the tweeter would overheat.
Evildude
Evildude
So basically if Im using too much treble it would be like using too much sharpness on a tv?
Long term, it's not good for your ears, either. The inner ear has little hairs, called 'cilia', that are there for taking the sound energy and stimulating the auditory nerve when they vibrate. Excessive high frequency content causes them to deteriorate or fall out, which means you won't be as sensitive to high frequencies. You can make it sound very similar by dropping the midrange a bit. Boosting the treble brings all kinds of noise with it and dropping the mids can actually decrease noise levels.
but they woud set the eq into the smily-face configuration anyway and a few days later we woud explain that the warranty doesn't include stupidity.
That's not very good customer relations and if the tweeters weren't nailed to the front of the cabinet, they'd be pushing up the daisies.
F
fredk
If you are cranking the trebble all the way up to get the sound you want there is something wrong. Speakers are designed to be played without the tone controls engaged. They are/were there to make minor adjustments to match your taste or to make up for room effects.
Even if you don't fry your tweeters, I expect that you are driving the tweeters beyond what they are capable of, introducing all sorts of distortion.
Considergoing to a local electronics store and find some speakers you like the sound of without cranking the trebble. Then, take your speakers to the store and compare them with and without the trebble cranked and see which set you like better.
Funny you should mention that, because that was one of the things that popped into my head in the 'somethings not right here' category.
Adam
Adam
I turned up the treble control when I was younger, and my speakers didn't break. Nor did my ears. Adjust the tone controls so that you like the sound (that's what they're there for), but as the others have said - be smart and don't play things so loud that your ears start ringing.
Things get so serious around here sometimes. :)
markw
And my brain......jeeze what is this a hand-holding session:eek:
Well, somebody's trying to hold something here, and I don't think it's our hands.
You outta check out this guy's other thread on this forum. They're biting like hungry sharks when you chum with fresh meat.
CraigV
CraigV
There was a guy on another forum who loudly & proudly proclaimed he had jacked all the EQ controls AND tone controls on his Onkyo SR605 to their maximum settings. He thought that he was getting better sound by getting more sound. It took a lot of responses to get him to set everything to neutral, and once he had time to listen to how things should sound, his eyes were opened to the fact that everything sounded more natural.
Cranking up tone/EQ controls makes more noise, not more sound;):cool:
