Is this 'too much' speaker for my receiver?
beerman1981
Hello,
I am thinking of upgrading my speakers. My receiver is an almost brand new Sony 2 channel (100 watts per channel). Here is a link to it.
Amazon.com: Sony STR-DH100 2-Channel Audio Receiver (Black): Electronics
I am thinking of getting a pair of Sony SSF-7000 speakers. Here is a link:
http://www.amazon.com/Sony-SSF-7000-Floor-Standing-Speaker-Woofer/dp/tech-data/B000OG4E2U/ref=de_a_smtd
Here are the specs:
Product Features
Newly developed 8" mica reinforced woofer
8" enhanced H.O.P. cone woofer
3.25" Mid-driver
1" Nano-Fine balanced dome tweeter
200-Watt maximum input power
Technical Details
Brand Name: Sony
Model: SSF7000
Color Name: Black
Speaker Type: Left / right channel speakers
Speaker Amplification Type: Passive
Speakers Response Bandwidth: Hz:35 - 50000
Speaker Connectivity: Wired
Depth: 11.9 inches
Height: 41.9 inches
Width: 11.4 inches
Weight: 33.1 pounds
Warranty: 1 year limited
I'm a newbie. Is this going to be too much speaker for my receiver? If not, do you think the sound will be compromised?
Thanks for any and all help!
Joe
I
Impelled
It will work fine.
The speakers are 8 Ohm which is easy to drive.
LAB3
LAB3
DITTO they will work OK together. I would purchased a sub next if you don't have one. Most towers with 8" woofers just donot have the Bass for good music and for Movies a sub is a Must if you like special effects to shake the room:)
Enjoy.
GranteedEV
GranteedEV
while I have my reservations about the sony, i honestly think you can do better as far as speakers are concerned.
Look into the Pioneer FS51s for example.
