Is this possible ....... rear wireless speaker kit
bradley0001983
So I have a rocketfish rear wireless speaker kit .. it's only 40 watts per speaker so not really good enough to drive my speakers however is it possible to hook my speakers up as normal with wire but also hook up the rear wireless speaker kit to boost the power or ad some height speakers it may be a dumb question but I am curious
BMXTRIX
BMXTRIX
No, you can't stack amplifiers. Yes, you likely could use them for rear-height... Or, perhaps speakers in zone 2.
Not sure what the kit consists of, so it may not work well at all for anything.
bradley0001983
The wires come out the terminal into the signal box then another box that has an amplifier to power the speakers I assumed it would just take the signal and power extra speakers my reciver is a denon x2400h and already using all 7 channels not very educated with it all so not sure how to make it work
