just-some-guy
just-some-guy
to replace my toshiba 32" that works fine and is going in the dining room.
it is just for basic tv watching. i'm figurin the pq will be plenty good enough.
i am mostly worried that it is kind of an older model. and that the price may drop soon after i buy (i HATE when that happens :mad:). it has been said that is has gone for under $500 at one time. perhaps the new models will come out soon, and this one will drop, and/or the new model will be better and cheaper = panny 3000/4000 ish.
idk, sometimes i can't make up my mind :eek:
http://www.amazon.com/dp/B001TA1DOC/ref=asc_df_B001TA1DOC1066864?smid=ATVPDKIKX0DER&linkCode=asn&creative=380341&creativeASIN=B001TA1DOC&tag=cnet-3554-20
just-some-guy
just-some-guy
well, wouldn't ya know it. my 32" went "pop" = dead.
checking it out, i found the "blue" rgb disconnected. how, idk. would this cause a problem ? the picture did look a little off today. it was on about 15 mins.
i took the back off and there is a black part, about the size of 2 aspirins stacked. that has burnt marks under it.
thought ?
just-some-guy
just-some-guy
14 months old. i started to try to use my mastercard extended warranty. one requirement is to get it estimated. so i started calling shops. from advice of a repair tech, i called toshiba. they may warranty it.
and the toshiba shop is right by my moms house = not far away :)
WISH ME LUCK !
i have since quit looking for a new set. i want to see how this pans out.
i am getting used to watching my 65" at 9' .
